أحمد ذكي
أحمد ذكي
Dec 13
Why does the remaining range drop so quickly when idling with the AC on? Stayed for two hours and the range dropped by 60 kilometers [crying]. Didn't even drive the car, is the fuel consumption really that high? Does everyone experience this?
خالد جعفري
خالد جعفري2024-09-26 04:26
The situation is like yours [I want to be alone].
علي جم دين
علي جم دين2024-09-20 09:56
The displayed fuel consumption is calculated by the system dividing the amount of fuel consumed by the distance traveled. When the car is idling and not moving, the mileage doesn't change at all, so the displayed fuel consumption will keep increasing!
فهد زبير
فهد زبير2024-09-20 06:23
That's estimated based on the current average speed. Actually, it's about more than 1 liter per hour. The onboard computer displays it.
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
When starting a cold car, the idle speed takes 5-6 minutes to drop below 1000 RPM, and the engine vibrates. I thought the throttle was dirty, cleaned it, but it didn't help. The oxygen sensor current shows -0.01 mA. The repair shop says it's fine, but I feel like there's an issue. What could be causing this?
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
Recently, the engine start-stop system suddenly stopped working, and I didn't turn on the AC. It's been less than three years and under 30,000 kilometers. Does anyone know the reason?
Today, while driving my 2020 automatic Chery Arrizo 5, I heard a squeaky noise from the accelerator pedal when I pressed it to accelerate. When I released the pedal, it didn't return to its original position and kept accelerating, which scared me, so I quickly braked and pulled over to turn off the engine. I then shifted to neutral and started the engine, which roared to over 4000 RPM. After turning it off, I manually adjusted the pedal, heard the squeak again, and then it started working normally. Occasionally, there's still a noise when pressing the accelerator, but the pedal returns to normal. Does anyone know what might be causing this issue or what might be broken?
Ford Taurus
Ford TaurusAED 108,580 ~ 186,795Gasoline & Petrol
