When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
Comments( 7 )
Hey everyone, just wanted to ask: Why does the JETOUR X95 blow hot air when I turn on the seat ventilation? Thanks!
Is there anyone else experiencing no hot air from the rear air vents in their Sharan?
For the 2017 GWM Haval model with 110,000 km, if the air conditioning isn't blowing air until the fan speed is set to maximum, or the AC needs to be turned off for a few seconds before air comes out, there might be an issue with the blower motor or the air vents. It's best to have a professional check the blower motor and the vent system for any blockages or mechanical issues.
4Hello everyone! I need some advice. When I turn on the AC, only the driver's side vents blow cold air, while all the other vents (passenger and rear) blow hot air, and it's really hot. Even when I close the vents, the area around them is still really hot. I went to the dealership, and they said I need to add refrigerant.
5When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
6I've got a 2014 Grand Cherokee, and lately when I turn on the heater, the driver's side vent blows cold air while the passenger side vent blows warm air. Does anyone know what might be causing this?
7Is there anyone who has added rear air vents for a small car? It's really hot in the back seat.
8The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
9When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
10Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
