خالد صعب
2024-09-21 01:32
The 2017 flagship model has a reverse rearview camera that doesn't tilt down, even though the setting is checked in the car's system.
خالد صعب
خالد صعب2024-09-22 01:08
Do I have to press like this every time I reverse? Can it be set up?
محمد ماجد
محمد ماجد2024-09-21 09:09
When reversing, you need to press the rearview mirror button on the left door panel.
I've upgraded my 2009 Scirocco with the 187b head unit, but the reverse camera doesn't switch the screen when reversing, although the radar works fine. Interestingly, the reverse camera works normally when the car is off, but not when the engine is running. I've already replaced the head unit and the reverse camera, but the issue persists. Any experts out there who can help?
Why won't the panoramic image open? Clicking it doesn't respond, and it also doesn't switch to the camera when I put it in reverse gear. What's the reason?
Does the 2012 Sportage GLS have a reverse camera? Sometimes when I reverse, it shows "searching for signal," and other times the central screen doesn't change.
Can you adjust the angle of the rearview mirror on the Geely? It feels like it's tilting too low... Or can it be set to tilt on one side only?
Can the 2015 2.0 Ultimate 508 be set to have the "adaptive rearview mirror during reverse" function? I've tried following the manual a couple of times without success. Does this version not have this feature?
Hey car enthusiasts, have you noticed this? When you're reversing into a parking spot, the car looks straight, but on the 360 camera, it appears skewed. Before, when I parked using the 360 camera, the image showed the car was straight, but once I got out, the front was actually tilted to the right. And when it seemed straight from the outside, the image showed it was slanted.
Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
Does anyone know how to adjust the brightness of the 2017 Skoda Kodiaq's infotainment system? I got a second-hand one, and I can't see the screen at all during the day. The reverse camera isn't visible either. I've already set the brightness to the maximum, but it's still not clear.
When I suddenly shift to reverse gear, the 360 camera doesn't display. The screen isn't even black; it shows nothing at all. Do you have any idea what could be happening?
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
