حسين أمينة
حسين أمينة
Dec 13
Taurus chassis noise I have a 2019 Taurus, bought in 2021, and it's now at 57,000 kilometers. Recently, there's been a serious noise coming from the chassis, and it gets worse as the weather gets hotter. When the vehicle goes over speed bumps or when the front wheels hit uneven road surfaces at different times, there's a squeaky sound from underneath, like metal rotating inside a rubber bushing. When entering the garage and turning the steering wheel left, there's a clunk noise from the front when the front wheels hit a speed bump. The same clunk noise happens when parking with the steering wheel fully turned while reversing. The noise is very uncomfortable. Any suggestions from fellow car enthusiasts? Has anyone else experienced this?
Comments( 9 )
خالد قادر
خالد قادر2024-09-23 12:01
Check the stabilizer bar bushing.
علي حارث
علي حارث2024-09-23 11:28
I also have a car from October 2021, with 36,000 kilometers on it, and I'm experiencing the same noise. It only happens when the car is warm. I went to the dealership, and they said it was the engine guard making the noise. After fixing it, the noise came back after a couple of days. I feel like it's probably not the guard causing the issue. Not sure where the problem is, maybe it's the CV joint or the steering rod.
خالد نايف
خالد نايف2024-07-15 03:03
I bought my car in 2022, and by the end of the year, it started making noises. It seems to be the same issue, and mine seems to be coming from the right side. The 4S shop couldn't identify the problem and just kept swapping parts, but it still didn't solve anything. Bro, if you find a solution, let me know so I can get it fixed too.
سلمان محمود
سلمان محمود2024-07-13 21:22
Have you changed the transmission oil? I'm supposed to change it at 46,000 kilometers, but I'm hesitant. Should I change it or not?
عبدالرحمن نور الدين
عبدالرحمن نور الدين2024-07-13 17:01
How's it going? I guess our cars were produced in the same batch with the same cable issue, having exactly the same problem. Did you finally get it resolved? [666]
فهد زايد
فهد زايد2024-07-10 08:22
Clunking sound, there's a "pop" when turning the steering wheel. Adjusting screws seems to fix it, but it reappears after half a year.
فهد زايد
فهد زايد2024-07-10 08:20
The front shock absorber was replaced under warranty, and the issue was resolved. On sunny days, on bumpy roads, there's a squeaky noise like a telegraph. When it's rainy and there's moisture, the noise disappears. It's not present when the car is cold, but becomes noticeable after it heats up. If this matches your situation, you might want to focus on checking the shock absorber.
عبد العزيز فهد
عبد العزيز فهد2024-07-07 04:02
It's common for Ford cars to have higher mileage.
عبدالله مجدي
عبدالله مجدي2024-07-04 20:02
Check the bushing; it might be worn out. Don’t replace the whole assembly, just the bushing. We can't get the original parts here. As for that clunk sound, it's hard to say where it's coming from.
When my car goes over a speed bump, there's a "clunk, clunk" sound. What could be the reason?
When driving over slightly rough roads, there's a clanking noise from under the front wheels, like metal hitting metal. Has anyone else experienced this?
Is there a clunking noise from the front left when driving on bumpy roads? Has anyone experienced this issue?
Is there any fellow Haval owner experiencing a clunking noise from the front right shock absorber when driving on rough roads?
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
Hello fellow car enthusiasts, has anyone installed coilover suspension on their car? Can it improve the chassis feel? My car is a 2017 4WD Elite with over 90,000 kilometers. When I go over speed bumps or drive on rough roads, the chassis makes a clunking noise. Will installing coilover suspension help?
Do you guys experience a squeaking sound when the front wheels go over a speed bump or curb?
What could be causing a clunking noise from the left front wheel on a 2013 Peugeot 508 2.3 while driving?
Ford Taurus
Ford TaurusBHD 10,200 ~ 12,800Gasoline
