عبدالله عماد
عبدالله عماد
Dec 13
Q: For the Taurus 8AT transmission, is it necessary to use a circulation machine to change the transmission oil? Is it required to remove the oil pan for cleaning?
Comments( 7 )
فهد لقمان
فهد لقمان2024-09-04 18:04
You can't use a fluid exchange machine for this transmission because you can't remove the oil pan or replace the filter. Using a fluid exchange machine can cause sludge to clog the filter, leading to poor transmission oil circulation and insufficient pressure in the torque converter.
عبد العزيز برهان
عبد العزيز برهان2024-07-19 11:54
Don't change it, changing it might actually affect the transmission.
سلمان محمود
سلمان محمود2024-07-13 21:20
I've driven 46,000 kilometers in over three years, and I'm unsure whether to change the transmission oil. Should I do it or not?
عمر لحود
عمر لحود2024-06-19 22:48
Has anyone followed the manual's recommendation of not changing the transmission oil for 240,000 km and driven over 200,000 km? [I want to be quiet]
عبدالله عماد
عبدالله عماد2024-06-19 19:15
The 4S shop said to use a recycling machine for replacement.
أحمد مجدي
أحمد مجدي2024-06-19 18:42
It's not possible to remove the oil pan. You can choose between circulation or gravity. Generally, gravity is recommended, but shops might suggest using a circulation machine to make more money.
أمين عبدالله
أمين عبدالله2024-06-19 17:51
I got it replaced at the 4S dealership with a circulation machine.
Is it necessary to change the transmission oil at 100,000 kilometers? I'm worried that the new oil might not be as good as the original old oil inside.
Do I need to remove the oil pan to change the oil?
How do you guys change the transmission oil, gravity or circulation?
Do I need to remove the oil pan to change the transmission oil for the 2019 GAC GA5?
Is it necessary to change the transmission oil at 40,000 kilometers?
Has anyone in the group changed the transmission oil for the 2021 JMC Ford Territory? This model doesn't have a transmission oil filter. Is it better to do a fluid exchange or a gravity drain by removing the oil pan? 🙏🙏
Has anyone with the 2019 GA6 changed the transmission oil? Is it necessary to change it?
How do I change the transmission oil for a Mazda 6 AT? Should I use the circulation method or the gravity method? It's currently at 76,000 kilometers.
Ford Taurus
Ford TaurusKWD 7,999 ~ 15,691Gasoline & Petrol
