سعود ضياء
2024-08-10 17:21
Only the driver's side keyless entry is working, and I've checked the settings, everything seems fine. The auto start-stop isn't activating anymore either, though I don't really use it. Has anyone else encountered the same issues?
Comments( 6 )
علي صلاح الدين
علي صلاح الدين2024-08-11 01:12
The battery is low on power, just charge it and it'll be fine.
عبدالرحمن نور الله
عبدالرحمن نور الله2024-08-10 22:51
You're gonna need to spend a few hundred bucks. 😄😄
عبدالرحمن ياسين
عبدالرحمن ياسين2024-08-10 19:13
The computer auto-start protection issue can be resolved by replacing the battery.
عبدالله حسين
عبدالله حسين2024-08-10 18:33
Why change the battery?
عبدالله مجدي
عبدالله مجدي2024-08-10 18:23
Go for a 50-kilometer drive on the highway and it will be fine.
حسن خالد
حسن خالد2024-08-10 17:27
Signs that your battery might be failing
The Touran's wipers don't have an intermittent setting. I've replaced the motor and checked the wiring; everything seems fine. Any car enthusiasts out there who understand this issue?
I reset the central control screen to factory settings. Now, the keyless entry can only lock but not unlock. How do I set it up? There is power! It seems to be protected. How do I unlock the system?
Hey fellow car enthusiasts, does anyone else have issues with their Haval H7 keyless entry being inconsistent? Sometimes it works fine, but other times it's unreliable. Especially on rainy days, it often doesn't work.
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
After leaving the 2012 Koleos in an open-air parking lot for half a month during heavy rain, the keyless entry on the front doors suddenly stopped working, while the rear doors are fine. Has anyone experienced this situation? Is it a wiring issue or are the keyless entry sensors malfunctioning? PS: It's not a key battery issue.
The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
My keyless entry only works on the rear side of the driver's seat. Is it broken?
Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦‍♂️
The newly introduced 009 has a comfortable entry and exit feature. However, every time I get into the driver's seat and press the brake, it doesn't restore the previous settings. I have to tap the upper left corner avatar and then select the previously saved driving preferences, which is quite troublesome. Does anyone know how to fix this? Thanks!
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
