My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
Hey guys, at how many kilometers did you change your spark plugs? 😎
How many kilometers do you guys usually change your brake pads? Yesterday, during maintenance, the technician said the brake pads need to be replaced, but I've only driven 40,000 kilometers. Shouldn't need to change them yet, right?
4How often do you guys change brake fluid? Looking for advice!
5Car enthusiasts, which brand of spark plugs do you recommend? Is everyone using Mitsubishi NGK single iridium spark plugs?
6Car enthusiasts: My Yuxiang has now run 50,000 kilometers. Do I need to replace the spark plugs? If anyone knows, please share. Thanks!
7Hey guys, at 90,000 km, do I need to change the spark plugs? If yes, should I go for Champion or Mopar?
8Hello everyone! Is it necessary to change brake fluid every 40,000 kilometers? How should I choose brake fluid? Which brand should I choose?
9How often should brake fluid be changed?
10My Taurus just hit 30,000 kilometers. What maintenance does it need? Do I need to change the spark plugs and brake fluid? Thanks, everyone!
