سلمان ذكي
2024-08-11 16:17
Is there a problem with the Taurus battery? I've had to replace it twice in three years, and this time there's sulfuric acid leaking!
عمر سعد
عمر سعد2024-08-12 20:34
Replacing a Camel battery is no problem.
حسن أبو بكر
حسن أبو بكر2024-08-12 12:36
There might be an issue with the connection. Please check it. I personally don't have the problem you're mentioning.
حسن حريري
حسن حريري2024-08-12 07:41
The battery can still be used after 3 years and 58,000 kilometers.
حسن فخر دين
حسن فخر دين2024-08-11 20:09
After 3 years, the auto start-stop feature is currently deactivated. The after-sales service says that if the battery is below 80%, the auto start-stop will be disabled.
حسن خالد
حسن خالد2024-08-11 16:20
Have you been fighting for three and a half years? Is there a power leakage? What modifications have you made?
Will the 720S still be available as a new car from the factory within three years? Or what model will replace it after three years?
Hello fellow car enthusiasts, I have a 2009 manual model. In the past two or three years, I've noticed that the braking power of the rear wheels has been continuously decreasing. I've consulted several repair shops and had it inspected, but no problems were found. I'd like to ask if anyone has solutions for this issue.
The battery life for a Territory PHEV (领界铂领) typically varies, but having to replace it twice in three and a half years seems unusual. It's worth checking if there are any underlying issues affecting the battery's longevity or if the specific usage patterns might be impacting its lifespan.
Four and a half years, and today my car actually had a spring pop out of the alternator. Really bizarre, it's the first time I've encountered this.
I've had my 2021 Jeep Compass for three years now. Last year, it was parked for half a month during the New Year, and the battery died, so I replaced it. In March this year, it was parked for over 10 days, and the battery was dead again. I replaced it with a new battery, and in May this year, after being parked for 9 days, the battery died again. What's going on?
Hi everyone, I have a question about my 2016 Nissan Sunny. Sometimes the car won't start on the first try, but if I turn the key off and try again, it starts. This happens every time I start the car. I've had the battery checked and it's fine, and I've also had the starter cleaned and maintained, but the problem persists. Does anyone know what could be causing this issue?
Does it need a battery replacement after six years?
RDX, the kettle has been replaced for the third time and it's still leaking. Is it beyond repair?
Why does the windshield washer fluid in my 2024 Arrizo 5 run out after just spraying three to five times? I've refilled it three times in a month and used it only about 10 times in total, each time just 1-2 sprays. Could the bottle be leaking? 😂😂😂
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
