How do you remove the rear seat cushion of a Taurus? I've managed to release the two front clips, but I'm not sure where the hooks are in the back where it meets the backrest. If any fellow car enthusiasts know, please let me know. Thanks!
I accidentally damaged the exterior door handle of my Smart car while using a heat gun to remove the film. Does anyone know where I can buy a replacement or how to fix it? Looking for advice from experts, thanks!
I watched a video where a fellow car enthusiast installed a tow hook on their SUV and discovered there's no rear bumper beam! Does anyone who owns one know if it's true that there isn't one?
The engine number for the 2008 2.5T Volvo C70 is typically located on the engine block. It's usually found on the passenger side of the engine, near where the engine and transmission meet. You might need a flashlight to see it clearly, as it can be a bit hidden. Make sure to check around the area thoroughly.
4Hey car enthusiasts, can you still buy old model car pedals? Where can you find them? Please let me know. 🙏🙏
5Hi everyone! Does anyone know how to replace the air conditioning filter for the 2019 model? How to remove the glove box on the passenger side? If you know, please let me know. Thanks!
6To replace the dust cover on the gear lever of a 2018 manual transmission ZS, follow these general steps: 1. **Remove the Gear Knob:** First, unscrew or pull off the gear knob, depending on its attachment method. 2. **Detach the Dust Cover:** Carefully pry off the trim panel around the gear lever to access the dust cover. This might require a trim removal tool to avoid damaging the panel. 3. **Remove the Old Dust Cover:** Once the trim is removed, you'll see how the dust cover is attached. It might be clipped or screwed in place. Remove any fasteners and take off the old cover. 4. **Install the New Dust Cover:** Position the new dust cover in place, ensuring it's aligned correctly. Secure it with the clips or screws you removed earlier. 5. **Reattach Trim Panel:** Pop or screw the trim panel back into place around the gear lever. 6. **Reattach Gear Knob:** Finally, screw or push the gear knob back onto the lever. Note: These steps are a general guide. It's always best to refer to the vehicle's manual or consult a professional for specific instructions related to your car model.
7To replace the gear shift boot on a manual 2018 MG ZS, follow these general steps: 1. **Remove the Gear Knob**: Unscrew the gear knob by turning it counterclockwise. Some models may have a clip or screw that needs to be removed first. 2. **Detach the Center Console**: Depending on the design, you may need to remove screws or clips holding the center console in place. Carefully lift the console to access the boot. 3. **Remove the Old Boot**: The boot is usually attached to the console with clips or staples. Gently detach it without damaging the console. 4. **Install the New Boot**: Secure the new boot onto the console by attaching it with clips or screws, ensuring it fits snugly. 5. **Reattach the Center Console**: Place the console back and secure it with screws or clips. 6. **Reattach the Gear Knob**: Screw the gear knob back on by turning it clockwise. Make sure everything is securely fastened and test the gear shift to ensure smooth operation.
8Does anyone know where to buy the clips for the roof trim strips? A few were broken when installing the film.
9Is there a good way to insert the airbag clip under the driver's seat after it's been removed? It's really hard to put back in.
10How do you remove the rear seat cushion of a Taurus? I've managed to release the two front clips, but I'm not sure where the hooks are in the back where it meets the backrest. If any fellow car enthusiasts know, please let me know. Thanks!
