عبدالرحمن شاكر
عبدالرحمن شاكر
Dec 13
Hey folks, the car is uneven on one side, the driver's side is 3cm lower. I've replaced all the springs and shock absorbers, and also changed all the chassis bushings, but it's still the same. The driver's side leans heavily when turning. Can any experts offer some advice?
محمد بهاء الدين
محمد بهاء الدين2024-11-19 01:10
I also have the front left lower and right higher issue. I measured it myself, and the difference is 1.4.
20
حسن رامز
حسن رامز2023-06-06 11:09
I've already changed everything that can be changed. So, I guess I'll just inflate the left tire more to physically correct it. [I need some peace]
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
I have a 2009 Toyota Yaris 1.6 automatic. Recently, the car has been making strange noises. It sounds like a spring or shock absorber is out of place. Does anyone know what the issue might be? Is it serious?
How does the C40's variable damping shock absorber chassis perform?
Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
I just got a 206, and I've noticed that the body is lowered. Is it coilovers or lowering springs? I noticed the rear chassis is different from regular cars. Any advice?
I've replaced the control arm ball joints, steering rack, and shock absorbers, but the chassis still makes a thumping sound. What could be causing this?
There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
Has anyone replaced the shock absorber bushings or other bushings on a 2015 Jetta? As for the engine mount rubber, if it's not severely damaged, should I continue using it?
Is the automatic anti-glare function for the exterior rearview mirrors on all Ford models only available on the driver's side, but not on the right side?
Ford Taurus
Ford TaurusEGP 1,906,698 ~ 2,424,600Gasoline & Petrol
