عبد العزيز طموح
2024-10-06 15:50
Hey car enthusiasts, has anyone experienced shaking during sudden acceleration? It shakes after driving steadily for a while, especially noticeable at high speeds. The 4S shop only cleared the previous driving habits, which improved slightly but didn't solve the root problem.
Comments( 6 )
خالد صعب
خالد صعب2024-10-28 17:33
American cars are all the same. Refueling will cause this problem, and starting up is also the same.
خالد قابوس
خالد قابوس2024-10-28 12:34
There’s no solution for resonance when the gear slips. Try manually downshifting with the paddle shifters.
نايف نوري
نايف نوري2024-10-14 18:53
I've experienced rapid acceleration vibrations and vibrations during cornering acceleration, which were resolved by replacing the half-shaft.
20
خالد حاتم
خالد حاتم2024-10-13 01:24
The fuel injector is having an issue.
نايف ياسر
نايف ياسر2024-10-12 11:26
Inspecting the half shaft.
حسن خالد
حسن خالد2024-10-06 16:39
The high-speed gear resonance is just how it is with this GM setup. If it's uncomfortable, switching to sport mode solves it. 😂 Alternatively, you can use a computer to increase the gear ratio by 500 RPM.
Help! When driving on slightly rough roads, the gear shift shakes a lot. Is there any way to fix it? I'm willing to offer a reward for anyone who can solve this problem!
How do you deal with this JBL sound system? The Bluetooth connection is really bad, and using a USB drive is only slightly better. You'd think with 9 loudspeakers, it wouldn't be this bad. And there's no CarPlay amplifier. How did you guys solve this?
Hi everyone, I need some advice. I have a 2015 1.4T Touran with nearly 110,000 KM on it. Recently, in the past six months, I've noticed that when making U-turns or reversing into parking spots, there's a sudden large resistance when turning the steering wheel. This doesn't happen during normal driving, only when suddenly turning the steering wheel. Can someone help me figure this out? Thanks!
Choosing between the R+ and S+ can be quite a dilemma, especially in a second-tier city without a race track and if you don’t drive aggressively. You were initially considering the S+, but many people suggest going for the R+ or not buying at all. The significant improvement in 0-100 km/h acceleration is indeed tempting, but the price difference of 200,000 is quite substantial. It’s understandable that you’re feeling conflicted.
I had a test drive and I'm really interested in buying. I just have two questions: First, after parking and braking, the car shakes a lot. Can this be improved later? Second, how advanced is the driver assistance? The staff just glossed over it without any introduction or demonstration.
I have a 2012 Subaru Outback with an EJ25 engine, almost 200,000 kilometers. It has noticeable shaking at idle and stalls during sudden braking, especially when the engine is cold. I cleaned the throttle body carbon build-up recently, which improved it a bit but didn’t completely solve the problem. The engine is quite loud during hard acceleration, and I’m not sure if it’s the engine or the transmission. Also, recently it shakes at speeds over 100 km/h. Anyone experiencing the same issues?
Hey everyone, I test drove the 2021 model today. While sitting in the back, the tire noise was quite noticeable. During the drive, the engine noise wasn't loud, but there was a bit of wind noise at 60 km/h. Can anyone tell me if the 2023 model has significantly improved sound insulation compared to the 2021 model?
When starting the 2014 GS5 2.0 automatic, the car shakes for about 10 seconds. It also shakes slightly when shifting from neutral to drive. Does anyone know the reason? Thanks 🙏🏻
When starting on a slope with a temporary license plate and using auto hold at a gate, the car tends to roll back when pressing the accelerator after the gate opens. Have any experienced car owners encountered this issue? How do you solve it? Should I use the electronic handbrake? PS. I didn't have this problem with my previous Volkswagen Golf. When stopped on a slope, I just kept the brake pressed and it moved forward when I pressed the accelerator, without rolling back.
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
