أحمد خليل
2024-08-25 10:15
Gear won't engage. Every time this happens, I just turn off the car, wait a bit, then restart, and it goes back to normal. Took it to the repair shop, but they couldn't find any issues.
عبدالله مجدي
عبدالله مجدي2024-08-29 10:25
I remember seeing this issue somewhere. You can check out videos on TikTok about this problem with Mondeo and Explorer.
عمر سعد
عمر سعد2024-08-27 15:24
Change the oil and then reset the transmission program.
عبدالله عماد
عبدالله عماد2024-08-25 23:45
I forgot to change the oil, how careless of me.
حسن خالد
حسن خالد2024-08-25 10:59
Check if the cable has deformed; if not, consider replacing the gear assembly. You can find one on Xianyu for a few hundred yuan.
When I put it in drive, the engine stalls. I have a 2017 model 95 with over 70,000 kilometers now. Recently, I've encountered a problem where the engine stalls when I put it in drive while waiting at a red light. It's happened a few times already, but the 4S shop couldn't find the issue. Has any fellow car owner experienced this problem?
Why does the start-stop function in the 2009 Smart cause the vehicle to stall? It usually happens when waiting at a red light. When the start-stop function is on and the light turns green, I find that the vehicle has already stalled, and I have to wait a moment before I can restart the vehicle.
Why does the car show a transmission fault warning during a cold start, but it goes away after waiting and restarting?
Occasionally, the vehicle loses gears while driving, but after restarting, it returns to normal. The repair shop couldn't read any error codes and initially suspects the mechatronic unit might be the issue. Are there any other owners with the same problem? How did you resolve it? Thanks 🙏
The central control screen won't turn off. When I press the switch, the screen goes black for a moment and then turns back on. Even a long press doesn't work. What should I do?
Is it a common problem that the wipers on the T99 couldn't be fixed after visiting three repair shops?
Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
Why does the economy mode in the Tanlu need to be set manually every time, and after turning off the engine and restarting, it automatically switches back to the standard mode? It seems like it can't be configured.
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
