فهد حارث
2024-09-24 09:50
Car enthusiasts, there's a set of test car parts available now: rear seats with electric adjustment and a full set of 14 loudspeakers, plus labor and wiring, all for 1.5. Is it worth it?
حسن شعبان
حسن شعبان2024-09-24 15:56
The rear adjustment is almost decorative and hardly used. It's better to go for a second-hand loudspeaker upgrade rather than installing a new one.
عبدالله مجدي
عبدالله مجدي2024-09-24 11:57
There is no point.
How can I solve the loudspeaker problem with the T5EVO? When listening to music, either the front has sound, or if adjusted, only the rear seats have sound. How can I set it so all loudspeakers work? There are 6 loudspeakers, but it feels like only the front two are working. [Crying][Crying]
There could be several reasons why the music USB drive isn't responding when plugged into the USB port of your car or other device: 1. **Compatibility Issues**: Some car USB ports or devices may have compatibility issues with certain USB drives or file formats. Ensure the music files are in a supported format like MP3. 2. **File System Format**: Check if the USB drive is formatted in a compatible file system, such as FAT32 or exFAT, which are commonly supported by car audio systems. 3. **USB Port Problem**: The USB port itself might be faulty. Try plugging the USB drive into a different port if available. 4. **USB Drive Issue**: Although it works on your computer, there might be an issue with the USB drive that affects its performance in other devices. Consider testing with another USB drive. 5. **Device Settings**: Check the settings of the device you're plugging the USB into. Some settings might need to be adjusted to read external USB storage. 6. **Power Supply**: Ensure that the device has enough power supply to read the USB drive, especially if it's an older model or if there are multiple devices connected. Try troubleshooting with these suggestions to identify the cause of the problem.
I bought the 2019 Bestune T99 in September 2020. Since it was my first car purchase, I lacked experience and fell into many traps. Besides having many minor issues, I later discovered several parts were damaged. The tires were previously used, which immediately made me suspect that this car was probably a test drive vehicle. And I was right. A few days ago, I went to replace the turn signal lights and found that the wiring inside had been reconnected, and the connections were poorly done. Moreover, the production dates of the left and right turn signals were almost a year apart. (Cars from the factory have uniform dates.) After all these years, it's impossible to explain this to the dealership now! I hope everyone pays attention to details when buying a car to avoid being deceived.
I've been driving a Touran for 7 years, and it's time for a change. I'm looking for recommendations based on my needs. Here's what I'm looking for: I commute 25km one way to work, and there's no fixed parking spot in my community. The city is crowded, which tests my driving skills, so the car can't be too big. I'd like a space for a nap at noon, so electric or plug-in hybrids are preferred. We are a family of three, and we often take the kid out on weekends, so the car's stability and smooth driving are important as my family gets car sick easily. I often take care of the kid alone, and since the kid is not very strong, an electric sliding door would be great. My kid likes camping in the car, so it needs to have ample space. Occasionally, I need to move things between houses, so flexible space is a plus. Since my wife doesn't drive, we can only have one car. Right now, it seems like the GAC E8 is the only option 🤣
I'm asking about the new 009 model regarding the HUD issue. I'm 186 cm tall, and during the test drive, I noticed that the HUD display is not fully visible. The top part is cut off due to the angle. I've already adjusted the HUD to the lowest position, and my seat is also set to the lowest and a relatively back position. Even then, in a normal sitting posture, the top of the HUD is still a bit cut off, and I have to lower my head to see all the HUD information. Are there any other owners with the same issue? Also, can the 009's HUD display information from QQ Music, like selecting a song to play or displaying lyrics?
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
