سلمان زياد
2024-09-28 23:06
Are there any fellow drivers experiencing severe rear tire wear? After 30,000 kilometers, the rear tire treads are down to the warning line...
عمر فخرو
عمر فخرو2024-09-29 23:26
The rear tires of this car wear out quickly.
خالد صعب
خالد صعب2024-09-29 23:03
Choose Michelin, it's top-notch!
عبدالله حسين
عبدالله حسين2024-09-29 11:38
My rear tires wore out after 50,000 kilometers. This car seems to wear out the rear tires quickly.
حسين أبو بكر
حسين أبو بكر2024-09-29 00:51
Check the picture, it can't be that bad.
I've been using the 2017 MDX for over a year, and the front tires are wearing out unevenly. After rotating the rear tires to the front and doing an alignment, the newly replaced tires are again showing severe uneven wear. Have any other car owners experienced this situation? Looking for advice.
Can a wheel alignment be done if the rear tires of a 2015 Sportage are wearing unevenly?
I'm looking for advice on my 2016 Volkswagen Multivan 4WD that's experiencing severe tire wear. I've done a wheel alignment, but it hasn't resolved the issue. Any insights would be appreciated.
Is there any fellow driver selling a foldable driver's side rear-view mirror for a 2007 Volvo S80?
Does the 2023 RAV4 still have rear tire wear issues?
Hello fellow car enthusiasts, does anyone know the length of the stock Land Cruiser with the rear-mounted spare tire?
I only replaced the front two tires, not the rear ones, and they're from two different brands. The tread patterns are quite different, and the load capacity and speed ratings aren't the same. Is this okay? Is there any risk? Do I need to replace the rear tires as well?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
Can the rear seats be folded down? Where can I adjust the height of the driver's seat?
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
