حسن علي
2024-08-10 20:56
After starting the 2019 Taurus, the steering wheel won't turn in place, even when reversing. It only turns when reversing while moving. However, it works fine when driving forward. Has anyone experienced this issue?
حسن شعبان
حسن شعبان2024-08-10 22:15
It seems like your power steering pump might be faulty. Try giving it a bit more gas when you start the car and see if you can steer the wheel normally.
Do your reversing assist lines move with the steering wheel?
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
Nissan Patrol, 98k kilometers. Now when I turn the steering wheel all the way, it gets stuck, and I can't turn it. Also, when reversing, it doesn't move. Has anyone else experienced this issue?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
Why does the newly purchased car make a slight noise when moving forward with the left rear wheel, but not when reversing?
Regarding the issue where the 360-degree camera system doesn't activate when reversing, but works fine when the turn signal is on, how can this be resolved?
Volkswagen Jetta 13 manual fashion 1.6 has a noise when turning the steering wheel. There is no sound when the steering is turned in place, but when driving and turning the steering wheel to the limit, it makes a noise. What could be the reason?
I've got a 2022 GTS with over 10,000 km on it, and I've noticed an issue. When I turn the steering wheel all the way while moving forward or reversing, there's sometimes a loud noise from the chassis. It sounds like something is stuck or like a brake squeal. Has anyone else experienced this?
There's a noise when the car is in reverse gear, you can hear a creaking sound, but there's no issue in forward gears.
Ford Ford Taurus
Ford TaurusAED 110,000 ~ 167,895Gasoline
