محمد نبيل
محمد نبيل
May 11
Why is it a 2.7t four-cylinder engine? Can such a big car really move with it?
Comments( 16 )
نايف حاتم
نايف حاتم2024-06-18 14:49
Whether it drives well or not, just go for a test drive when the time comes.
سعود أمين
سعود أمين2024-06-17 01:30
Are you questioning the L3B?
سلمان أبشير
سلمان أبشير2024-06-12 22:38
You've already mentioned the T, so what do you think? It's just a 0.3 difference from the 3.0V6. If you're really concerned about those 20-30 peak horsepower that 0.3 brings, would you pay hundreds of thousands more for the 3.0V6? 😊
حسين مبارك
حسين مبارك2024-06-01 14:05
Just look at the engine displacement [I want to be quiet], it's not a broken three-cylinder anyway.
آسيا عبدالرحمن
آسيا عبدالرحمن2024-05-31 15:40
The GM L3B engine is a 2.7T four-cylinder with 500 N·m torque (1500–4000 rpm). If you switch to the GM 3.0TT V6 LGY engine, the peak torque range might be higher, but the peak torque only increases by 49 N·m. It will likely consume more fuel on the highway compared to the 2.7T, as the four-cylinder L3B features cylinder deactivation.
عبدالرحمن أكرم
عبدالرحمن أكرم2024-05-24 02:37
Do you think you're better than GM? Would GM import a car that can't run? The current situation is that as long as it's enough, it's fine.
علي صباح
علي صباح2024-05-20 22:22
Even if they give you a V6 or V8, you guys will say the fuel economy is poor. Haha, netizens always find something to complain about.
خالد باهر
خالد باهر2024-05-20 19:50
Sure, just bear with it. [Grin]
عبدالله جلال الدين
عبدالله جلال الدين2024-05-18 19:39
Trying the Prado 2.7's 0-100 km/h acceleration makes you question life.
فهد رامي
فهد رامي2024-05-17 15:56
What should I do with the Mercedes-Benz GLB 7-seater 1.3T? Should I cancel the purchase?
Chevrolet Tahoe
Chevrolet TahoeBHD 16,600 ~ 31,103Gasoline & Petrol
