Why doesn't such a big car use the CT5-V's 3.0T V6 gasoline engine? That's not very American. 🤦♂️ I can understand not using a V8, but going straight to a 4-cylinder, what's up with that?
I understand you're curious about the power ratings of the MC20, Roma, and McLaren GT. The Maserati MC20 with its 3.0T engine is rated at 630 horsepower, while both the Ferrari Roma 3.9T and McLaren GT 4.0T are rated at 620 horsepower. It's understandable to question if the MC20's rating might be inflated, but manufacturers use different technologies and engineering approaches to achieve their horsepower figures.
