عمر نايف
2024-10-08 22:07
Isn't 2.7t too sluggish?
Comments( 14 )
حسين قيس2024-11-23 13:16
A four-cylinder engine in a big car, even if it can run, the high-rev noise from the back is loud and cheap-sounding. There's nothing you can do about it.
باسل حسن2024-11-23 11:25
There are no timid cars, only timid drivers. I’ve been driving a 2.7L naturally aspirated Prado for over 4 years now. [I want to be alone]
عمر أم2024-11-23 10:15
I went for a test drive. It's like the worst of the worst. The engine roars loudly but just can't move. You can't even shift manually; the paddle shifters only work at low speeds.
قيس سلمان2024-11-21 23:27
You should definitely go for a test drive, don't just listen to others. [I need some quiet] Test drives are free.
2
عبدالله ميمون2024-11-21 22:52
The 2.7 engine tends to accelerate faster than the 6-cylinder and 8-cylinder engines. Its low-end torque performance is also quite good.
نايف فادي2024-10-18 11:57
The Land Cruiser 570's V8 is said to do 0-100 km/h in about 9-10 seconds.
حسن جعفري2024-10-18 11:51
Once you're used to driving a Mercedes V260, you'll definitely be able to handle it. [I need some quiet time]
عبدالله صباح2024-10-18 09:15
For a pure gasoline car, the engine noise at high throttle is probably quite noticeable. Additionally, the fuel consumption might be too high for most people to afford. Maybe having a hybrid would be a better option.
حسين عمر2024-10-17 16:53
It's actually okay, but not suitable for impatient drivers. In normal mode, the turbo lag is more noticeable compared to smaller cars, so you need to get used to it. The engine noise is also quite loud.
حسن أنور2024-10-15 19:50
You should know there's a method called reprogramming.
