I put down a deposit at the auto show mostly for the excitement, since I wouldn't actually buy a 4-cylinder. But today my friend at the port said no one's handling the 3C for the Tahoe... Currently, only the old model of the big Tahoe is available, and it's unlikely we'll see the 8-cylinder or diesel Tahoe at the port this year. That's awkward.
Comments( 12 )
Today I was driving my MG One and stopped at a red light. I put the car in park, and when the light turned green, I shifted to drive. Suddenly, the car system reported that the battery was dead and there was an engine fault code. The car wouldn't move even when I pressed the gas. After turning off the engine and restarting the car, it was able to move again, and the fault code disappeared. I went to a friend's repair shop to check, but they didn't find any issues. Since I was at the traffic light and the car behind kept honking, I didn't have time to take a picture. I'm a bit regretful about that. When I go to the 4S shop, I'm not sure how to explain it.
