عمر يعقوبي
2024-08-14 18:27
Have you already placed an order? What are the discounts in major cities across the country? What are the policies for imported cars? Let's help each other out to avoid any pitfalls!
عبد العزيز مدرسي
عبد العزيز مدرسي2024-08-20 19:03
At the beginning, there definitely won't be any discounts, no need to even think about it. This price isn't meant for mass sales. Later on, I personally predict the most you'll see is a small discount.
حسن ناصر
حسن ناصر2024-08-20 18:25
There's no discount on the Chevrolet Equinox. You can forget about waiting for a discount on this car.
2
باسل حسن
باسل حسن2024-08-19 11:38
Let the bullet fly for a while [grin]
سعود سلمان
سعود سلمان2024-08-19 09:23
It's definitely not cheap just after being launched!
خالد قربان
خالد قربان2024-08-18 13:05
It is said that there is a uniform pricing with no discounts available.
Chevrolet Chevrolet Tahoe
Chevrolet TahoeAED 245,000 ~ 321,000Gasoline
