سلمان قاسم
Nov 13
I've been driving my T-Roc for two years, covering 10,600 km. In the past year, there's been a constant squeaking sound while driving, starting right after leaving the garage. It's also begun to make a squeak when I brake. The 4S shop said it's because Volkswagen brake pads are relatively hard and suggested braking hard a couple of times at high speed to fix it. Does anyone know what could be causing this and how to deal with it?
During the rainy season, my car has been parked outside for the past few days. After starting the car and pressing the brakes, I hear water sounds from the chassis. I've checked the sunroof and there's no leak, also tested the floor, and it's fine. Could it be that the frame has taken in water? Can any expert analyze this?
Hello fellow car enthusiasts, I have a 2009 manual model. In the past two or three years, I've noticed that the braking power of the rear wheels has been continuously decreasing. I've consulted several repair shops and had it inspected, but no problems were found. I'd like to ask if anyone has solutions for this issue.
My car was involved in an accident in 2018, affecting the front bumper and radiator area. It was repaired at the 4S shop. For the past four years, there were no issues during the vehicle inspections. However, this year, the inspection technician said that the vehicle identification number in the engine compartment had been altered. What's going on with this?
4I've been having heavy snow here the past couple of days. The car starts to skid once the speed goes over 20. Neither the snow mode, standard mode, nor sport mode seems to work. How about you guys?
5I'm driving a 2017 model 1.4T automatic 2WD luxury version. Last year, I replaced the recalled vacuum pump. When I used to drive it daily, I didn't notice any issues. Recently, I've been using the car less, and after it's been parked for a day or two, the brakes feel hard when I start it in the morning. I wanted to check if the vacuum is sufficient, so I tried coasting in neutral and after pressing the brakes a couple of times, they become hard. I want to ask fellow car owners if they've experienced the same situation. Thanks.
6Hi everyone, when waxing my car, should I use solid wax or liquid wax? It's been a year, and I want to maintain the paint. I used liquid wax because the guy at the car wash said that due to the many angles and folds on the car, solid wax might leave white residue. In the end, I used liquid wax, but the results weren’t great. 🤦♂️
7I've been driving a Peugeot 307 for over ten years and I'm ready to change cars. However, I feel like it's hard to find a car in the same price range that matches its safety, stability, and handling. Does anyone have any recommendations?
8For the 2017 Middle East version of the 3.6 Grand Cherokee, the central control system is entirely in English. Is it possible to replace it yourself with a Chinese interface that includes CarPlay? Also, in the past couple of years, the fuel pump often stops automatically while refueling, which is likely due to high fuel tank pressure. How can this issue be resolved?
9Why do I hear a sharp "squeak" sound when releasing the handbrake? This has only started happening in the past year.
10Why are there grooves on one of the brake discs of a car that's been used for five years?
