I just got the Chen Guang version and I'm using 92 octane fuel. Is that okay? Should I switch to 95 octane or continue with 92?
Comments( 8 )
I'm asking for advice from the experts here. I have a 2016 Ford F150 XLT that's run 40,000 kilometers. I've always used 95 octane fuel. Is it okay to switch to 92 octane? Thanks!
Do I need to fill the P1 with 92 or 95 octane fuel?
Does the 2011 MDX use 92 or 95 octane fuel?
4Switching from 92 to 95 octane gasoline for your 2018 Jeep Renegade 4WD model might be beneficial for the engine.
5Can using 95-octane fuel provide a power boost for a vehicle like the Kia Sportage that specifies 93-octane (now equivalent to 92-octane)?
6Should I use 92 or 95 octane gasoline for the Volkswagen Touran 2.0 naturally aspirated engine?
7Should I use 92 or 95 gasoline for the 3.6 version?
8In 2022, the car required 95 octane fuel, but for the 2024 model, it uses 92 octane fuel. I checked and it seems like nothing has changed. Why is that?
9I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
10Is it okay to use 92 gasoline for a 1.4 engine? I bought a second-hand car, and the dealer filled it with two tanks of Sinopec 92. Should I switch to 95 later on?
