How do I switch from 92 to 95 after using 92 for the first tank of fuel?
Comments( 9 )
I want to ask about the Haval H7. Do you use 95 or 92 petrol? I've been using 95, but it doesn't seem to work well. Is it okay to use 92? Any advice, friends?
I want to ask, for the 2002 model with a 2.4 engine, if I switch from using 95 to 92 fuel long-term, will it cause any issues?
Do I need to fill the P1 with 92 or 95 octane fuel?
4What do you think, is it better to use 92 or 95 for better performance? I've always used 95, but I've heard that 92 might give more power.
5Does the 2011 MDX use 92 or 95 octane fuel?
6Hey everyone, for the V40, should I use 92 or 95 fuel? And how many colors are available for the ambient lighting?
7Is the 2019 model V97 using 92 or 95 fuel?
8What type of gasoline do you use for the 1.6T 3008, 92 or 95?
9I've been using 95 octane fuel for two and a half years. Should I continue with 95 or switch to 92? Thanks.
10Is it okay to use 92 gasoline for a 1.4 engine? I bought a second-hand car, and the dealer filled it with two tanks of Sinopec 92. Should I switch to 95 later on?
