Why has there been frequent gear lag recently? It's a 2019 model with a 1.4T dry dual-clutch. After picking up speed and then braking, the gear doesn't match the speed. For instance, it's in 6th gear at 45 km/h and 5th gear at 35 km/h, but it doesn't downshift further. It upshifts quite eagerly. Went to the 4S shop, and they said the engine isn't strong enough, and the gearbox can't be adjusted?
When driving at speeds between 50 to 70 km/h, should I use fourth gear or fifth gear? I've just got my license.
Fellow car enthusiasts, have you experienced slow shifting between the 6th and 7th gears with your 7-speed dry dual-clutch transmission? Mine doesn't shift to 7th gear even at 80 km/h and waits until it reaches 85 km/h. Is this normal?
How can I remove the 120 km/h speed limit?
4When driving at speeds between 80 and 90 km/h, the car's chassis vibrates, but it becomes smooth again at speeds of 100 km/h. What could be the reason for this?
5How much is the fuel consumption at a constant speed of 120 km/h with the air conditioning on?
6I recently got a 2013 1.4T VW Touran with 110,000 km on it. It's been owned by one person before me. Currently, the big electric fan isn't working, but the small one still is, and the water temperature isn't high. I'm planning to replace it in a few days. The only issue right now is a whistling noise in 5th gear at 70-80 km/h. It doesn't happen in 4th gear, only in 5th when I accelerate, and it stops when I release the gas. 🙂?️ Seeking advice from experts—is this a transmission problem?
7When merging onto the highway with a CX-30 MT, which gear do you use to accelerate? From 50-80 km/h, there's not much power in 4th to 6th gear. Do you need to rev it up to 100 in 3rd gear?
8Car enthusiasts, do you think that by changing the gear ratio and using 95 octane fuel, there's a chance to reach a top speed of 190 km/h? 😁
9I have a 2021 model Santana. When I'm driving between 50 to 60 km/h, the gear is in 5th, but the display shows 2nd or 3rd gear. However, the 2nd and 3rd gears seem to be neutral. What's going on?
10Why has there been frequent gear lag recently? It's a 2019 model with a 1.4T dry dual-clutch. After picking up speed and then braking, the gear doesn't match the speed. For instance, it's in 6th gear at 45 km/h and 5th gear at 35 km/h, but it doesn't downshift further. It upshifts quite eagerly. Went to the 4S shop, and they said the engine isn't strong enough, and the gearbox can't be adjusted?
