Which brand of brake pads is good for replacement?
Which brand is good for replacing the central control screen in a Jimny?
Should I replace the brake pads with better ones or go for the original ones? What brands do you guys usually choose?
Which brand of tires is good and affordable? 😂
4Which brand of wiper blades is good to buy?
5Which brand of brake pads is good for replacement?
6How many kilometers should the brake pads be replaced on a Smart 453?
7Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
8What brand are the original brake pads, or can anyone recommend a good type of brake pads? Thanks!
9Hi everyone, I'm looking for advice from fellow Grand Cherokee owners. A braking distance of 43 meters seems pretty bad. Has anyone done any modifications? What brands did you use? Is it enough to just replace the brake discs, calipers, and pads? What's the braking distance after modification? Also, has anyone switched to LED headlights? How's the performance? Which brand did you go with?
10I've replaced the brake pads and discs on my Mazda6, and also changed the brake fluid, but the brakes still feel very soft and don't stop well. What could be the issue?
