Where should I apply sealant if there's a water leak in the engine compartment? 🤔
Where is the water temperature gauge?
How to fix a water leak in the rear hatch ceiling of a 2011 Kia Sportage?
Is the Genesis GV70 engine idle vibration very noticeable? I saw a short video where a bottle of mineral water was placed on the engine, and it moved to the edge and fell over.
4Hey Swift buddies, can someone tell me where the water leak is if there's water accumulating under the rear seat on the driver's side during rainy days? There's no water anywhere else, just this spot on the left side of the rear seat.
5Where is blocked if water leaks from the bottom of the A-pillar during a car wash?
6Jetur X70, 2020 model. I started having a coolant leak, and when pressure was applied, the leak point was found. The four-way valve was replaced, and the heating pipe and water inlet pipe were tightened. It was also discovered that the water pump was leaking, and eventually, everything was replaced. However, after refilling the coolant, the mechanic found that the engine temperature was high, but it drops as soon as the heater is turned on. They spent half a day but couldn't find the problem, and the car not being fixed has caused a lot of issues. Have you encountered this before? How did you handle it?
7What's going on with the Skoda Kodiaq A-pillar leaking water when it rains?
8What's causing water under the passenger seat and rear floor mat of the Haima S5? Where is it leaking from? If anyone knows, please reply, thanks!
9Where should I apply sealant if there's a water leak in the engine compartment? 🤔
10What's going on with the water leak from the A-pillar in the 2019 manual luxury version?
