When you accelerate above 50 mph, there's a clicking noise, like "ta-ta-ta," but there's no noise when you're not accelerating! I'm not sure what's going on. Looking for some advice.
When the Prado 4.0 is between 40 to 50 mph, the steering wheel vibrates, and there's a humming sound.
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
4The 2017 Land Cruiser with an automatic transmission struggles to accelerate when flooring the gas pedal, with the RPM not going above 2300, causing slow acceleration. However, when using cruise control, the acceleration is faster, and the RPM can increase. What might be the reason for this?
5Hi everyone, I have a 2015 GS5, 2.0. When I go above 60 mph, it feels very weak and sluggish, and I have to accelerate gradually. Is this normal?
61.4T T-Cross, there's a buzzing sound when accelerating above 60 km/h, but no sound when not accelerating. Looking for answers to the issue.
7When you accelerate above 50 mph, there's a clicking noise, like "ta-ta-ta," but there's no noise when you're not accelerating! I'm not sure what's going on. Looking for some advice.
8For a 2013 Suzuki Swift, if you're experiencing a buzzing noise at speeds of 40 km/h and above, and the noise gets louder as you go faster, what can you do to reduce the sound? Any advice from experts would be greatly appreciated. Thank you!
9Why is it making a rattling noise when I put it in reverse gear recently? Can any experts give some advice?
10Changan CS95 accelerates at 40-50 mph with high RPM but lacks power. What could be the issue?
