The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵💫 Do any other T-Cross owners experience this situation?
I want to ask, I bought a new car and have driven 2000 kilometers, the car is overheating, and the water temperature gauge shows 90 degrees. How can I solve this issue?
Is it normal for the Sharan to shift gears at 3000 RPM when climbing?
Has anyone experienced idle running at 1000 RPM when the temperature is 35 degrees, and then it returns to normal at 800 RPM when the temperature is 26 degrees? What's going on? Please help.
4Is it normal for the water temperature of a 2015 Peugeot 508 to be around 90 degrees? [crying][crying][crying]
5Is it normal for the idle speed of a 2015 Volkswagen Touran to rise to 900 RPM when the outside temperature is below 0 degrees while the engine is warm?
6As a newbie, which one is more worthwhile, T-Cross or Tharu? My budget is around 120,000 RMB.
7The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵💫 Do any other T-Cross owners experience this situation?
82017 model 1.4T, now the temperature is around 3°C. When I start the car, the RPM is at 1200, and when I start driving with a cold engine, the RPM goes above 3000 before it shifts gears, and it feels shaky. Do you guys experience this too?
9When I start the car, the idle speed is around 2000 RPM, but after a while, it drops to 1500 RPM. It takes quite a long time to go down to around 1000 RPM. Does anyone know what's going on?
10Are there any T-Cross owners here? Is your car shifting smoothly? I feel like my gear shifts are quite slow.
