The battery couldn't start the car after 3.5 years and needed replacement, even though the auto start-stop feature was mostly off. Fellow car enthusiasts, when did you replace your battery for the first time?
Comments( 8 )
What could be the issue if the auto start-stop feature on a 3.0 Grand Cherokee hasn't worked since I bought it less than a year ago?
How do I turn off the auto start-stop on the ILX? 😅
Is there anything other than a battery issue that could cause the auto start-stop to show the battery not fully charged on a three-year-old car?
4Does the 2021 Fengxing T5 EVO have an auto start-stop feature? It seems like it doesn't, but I'm not sure. I need to change the battery, but I'm not sure if it has the auto start-stop function.
5How do I disable the auto start-stop feature on the 2015 Subaru Outback?
6After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
7Has anyone replaced their car battery? I drive often, and last night the battery was dead and I couldn't start the car. Have you guys encountered this before?
8The battery couldn't start the car after 3.5 years and needed replacement, even though the auto start-stop feature was mostly off. Fellow car enthusiasts, when did you replace your battery for the first time?
9When I start the car, the dashboard shows "Auto Start-Stop Unavailable" and then "Check Engine". What's going on? I just replaced the battery not long ago.
10Where is the auto start-stop switch for the Jetour X90 PLUS?
