حسن عبد له
2022-03-15 22:12
The auto start-stop function on my 2020 model 280 Comfort version has been inactive for a month. No matter how I park, it won't activate. What could be the issue?
Comments( 12 )
فهد شهيد
فهد شهيد2024-01-22 16:10
The air conditioner seems to be running continuously.
عبدالله عمر
عبدالله عمر2024-01-02 15:06
How did it break? I also want to permanently disable this feature.
مروان عبد العزيز
مروان عبد العزيز2022-03-22 18:21
It's perfect that such a useless feature stopped working.
عبدالله حموي
عبدالله حموي2022-03-18 11:38
My 1.4T 2019 Comfort Edition with Start-Stop used to work when the car was new, but now it doesn't respond at all.
سلمان طل
سلمان طل2022-03-17 12:36
Everyone must be envious of you.
علي كامل
علي كامل2022-03-17 11:36
I haven't encountered this situation, but it seems like everyone is envious of you for not having to manually switch the automatic start-stop function. Of course, I'm quite envious too. Haha [I want to be alone]
حسين ياسين
حسين ياسين2022-03-17 09:06
The battery voltage is low. Replacing the battery or not using it permanently doesn't really help much. The auto start-stop feature is surprising!
أمير عبد العزيز
أمير عبد العزيز2022-03-16 22:30
The battery might be drained due to frequent short trips, right?
علي كامل
علي كامل2022-03-16 18:03
It might be that the start-stop battery is dead.
عمر صابر
عمر صابر2022-03-16 14:48
It seems mine also stopped working recently. It's a 2020 model with a 1.5L engine.
Does anyone know if the Changan Yuexiang from LinkTour has the auto door lock feature? I've tried many setup videos but haven't succeeded. No matter the speed, the doors won't lock automatically. Help! Help! Help!!!
Is there a problem with the car if the auto start-stop system, once activated at a red light with a deep press, automatically reignites due to the long red light duration and causes noticeable shaking?
Has anyone else encountered this issue? Recently, when I activate the auto hold, after the car stops, the AVH light blinks and then there's a clicking sound. It happens every time. If I press the brake harder, the sound is louder; if I press lightly, the sound is softer.
Why can't the cruise control on the LC300 be activated? It shows OFF and won't turn on no matter what I do.
Does the 2021 Fengxing T5 EVO have an auto start-stop feature? It seems like it doesn't, but I'm not sure. I need to change the battery, but I'm not sure if it has the auto start-stop function.
Hey folks, has anyone experienced issues with NetEase Cloud Music not playing? I parked for a day and then it stopped working. Voice commands can wake up and execute on Zebra, but NetEase Cloud just won't play. Even restarting the car system doesn't help.
Only the driver's side keyless entry is working, and I've checked the settings, everything seems fine. The auto start-stop isn't activating anymore either, though I don't really use it. Has anyone else encountered the same issues?
The battery of the JETOUR X95 is dead, and the remote key buttons are not working. After jump-starting the car, the emergency braking system activated. The car can drive normally, but the dashboard is only partially functional, as the idle speed and speed are not displayed. I tried to reprogram the keys because I have four keys, and the previously working key is not functioning anymore. However, I'm unable to successfully reprogram the key, and now the car won't start. Has anyone encountered this issue before? How was it resolved? This is the 2020 JETOUR X95 dual-clutch version.
I've had my car for over a year, and the auto start-stop has never worked. I went to the dealership, and after a test drive, the service staff said it works, but I need to turn off the AC for it to function. I've turned it off, but it still hasn't activated. How do you guys use it?
