حمد عبدالرحمن
2024-07-06 16:55
Squeaking noise~ I can only come here to ask all the experts.
حمد عبدالرحمن
حمد عبدالرحمن2024-10-17 09:56
There was no return trip on the same day. It seems there was some kind of metal chain placed on the door separator.
My Hyundai Accent's front left shock absorber makes a squeaking noise on uneven roads, but there's no noise on flat surfaces. Why is that, and how can I fix it?
Hey experts, can I ask you something? My car is making a squeaky noise while driving, what could be the reason?
I bought the lowest trim of the automatic model. Is there a similar version? I want to ask if the trunk comes with a storage board. My car didn't come with one, and they said only the higher trims have it. Can someone explain this?
When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
Can the Ousheng be optioned with an electronic parking brake and a 48V dual generator from the factory? I saw a video last night showing the new car equipped with an electronic parking brake, so I'm here to ask the experts.
There are knocking noises coming from the chassis, like "gudong gudong" and "gadeng gedeng". I replaced all 4 shock absorbers, but the noise persists. I checked the ball joints and the steering rack, but everything seems fine. Not sure where the noise is coming from in the Peugeot 301.
There is a squeaking noise when the steering wheel of my 2008 Kia Sportage is turned all the way. What could be the problem?
I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
Has anyone experienced this? The X90plus's wipers make a squeaking noise after only six months?
