عبد العزيز جمال
2024-05-12 13:21
Is there a replacement installation tutorial available?
عبدالله عوادة
عبدالله عوادة2024-05-14 23:47
The part you're referring to is the window regulator assembly. You can take it off and have it repaired by a TV or electronics repair technician. To remove it, use a plastic prying tool to gently lift it up, as it's held in place by clips. Be careful not to use too much force to avoid breaking it. Alternatively, you can buy a new central control module for replacement, which costs less than 100 units.
