سعود فارس
2024-12-01 19:15
How is the power of the 1.5L engine? Can it handle a full load uphill on rural roads?
علي زبيدي
علي زبيدي2024-12-02 23:19
As long as the engine displacement is 1.5 or below, including 1.5 without a turbo, all manufacturers are basically the same, except for manual transmissions.
سعود يعقوبي
سعود يعقوبي2024-12-02 21:12
I also have the 1.5L. As long as I give it enough fuel, I don't think it's a problem.
عبدالرحمن سعود
عبدالرحمن سعود2024-12-02 20:20
When driving on uphill or downhill sections, switching between manual M mode and D mode, the car doesn't move.
Is a 1.5L engine powerful enough for such a large car?
To determine which is larger, a 1.5L engine or a 1.4T engine, you need to understand the difference between naturally aspirated engines and turbocharged engines. A 1.5L engine refers to a naturally aspirated engine with a displacement of 1.5 liters. On the other hand, a 1.4T engine has a displacement of 1.4 liters but is turbocharged, meaning it has a turbocharger that increases its power output. In terms of displacement alone, 1.5L is larger than 1.4L. However, the turbocharger in the 1.4T can provide additional horsepower and torque, potentially making it feel more powerful than the 1.5L, depending on the specific engine designs and tuning. So, if you're looking at just the displacement, 1.5L is larger. But in terms of performance, the 1.4T might offer more power due to the turbocharging.
Is the entire series equipped with chassis lifting, and how high can it be raised? Can it handle rural roads when going back to the hometown during the New Year?
How many kilometers can a full tank last for a 2015 Haima S5 with a 1.6L naturally aspirated engine?
Hey everyone, I'm getting my car next week. How's the chassis performance? Can it handle driving in rural areas?
Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
How many kilometers can it run on a full charge and a full tank?
How many kilometers can a T-Cross 1.5L travel on a full tank?
Is it lacking power, even struggling on uphill roads? Is this common or is there a specific reason?
How to handle the occasional engine warning light in the 2020 MG ZS?
