How do you control the window lowering with the remote on the 2022 T-Cross 1.5 NA version? Can any fellow car enthusiasts give some guidance? 🤗🤗🤗
I want to ask fellow car enthusiasts! How do you activate the one-touch window lift function on the 2022 model?
The co-driver's window of the Mitsubishi Eclipse Cross can only go up but not down, and the main driver's switch can control the other three windows except the co-driver's, which can only go up but not down. The co-driver's switch also only allows the window to go up but not down. What could be the reason for this?
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
4How do you control the window lowering with the remote on the 2022 T-Cross 1.5 NA version? Can any fellow car enthusiasts give some guidance? 🤗🤗🤗
5Can I install an internal tire pressure monitoring system for my Volkswagen T-Cross? Could you please recommend some reliable brands? Thanks for your suggestions!
6Does the T-Cross have matte black or other black wraps available? Share some pictures if you have them. 👀
7Does the 2022 Roewe RX5 Max have the feature to roll up windows when locking the car? Fellow car enthusiasts,
8Fellow car enthusiasts, does your 2018 manual comfort model have the feature to lower the windows by long-pressing the unlock button on the key?
9Can the new Jetta's headlight cover, which is higher than the grille, be adjusted to be level? Any car enthusiasts who know about this, please give some guidance.
10Hi guys, how's the upgrade from the 2021 luxury model to the 2023 new car system? Any experts here to give some guidance?
