حسن زيد دين
2021-05-14 12:55
Hello expert, I bought a Volkswagen T-Cross in June 2020. Last night, when the vehicle started and moved about twenty meters, it suddenly stopped as if the chassis had hit a rock. Could you please tell me what the reason might be? Thank you!
فهد رومي
فهد رومي2024-04-25 21:34
Warning: Automatic Braking System Failure
أحمد عبد الغفار
أحمد عبد الغفار2024-04-25 17:25
In the same situation, a big red car icon appeared on the dashboard and disappeared within a few seconds while driving. What's going on?
عبدالله باسم
عبدالله باسم2021-05-14 18:30
Collision Warning Brake Assist
أحمد ثاني
أحمد ثاني2021-05-14 14:30
Just restart and it will be fine.
2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
Volkswagen T-Cross
I've driven my father's manual Volkswagen Santana for over 10 years. It's quite durable, performs well on the highway, and the wind noise insulation is decent. It hasn't had any major issues. I'm planning to switch to an SUV to experience driving one. I want to ask T-Cross owners: Is the T-Cross reliable? How is the driving experience on the highway, and what about the wind noise insulation?
Can I install an internal tire pressure monitoring system for my Volkswagen T-Cross? Could you please recommend some reliable brands? Thanks for your suggestions!
Does the T-Cross have matte black or other black wraps available? Share some pictures if you have them. 👀
I'm looking to buy a 2023 Volkswagen T-Cross 1.5L Naturally Aspirated, Automatic Comfort model. I want to ask everyone if the current 2023 models on sale have a particulate filter. As far as I know, the 1.4T model does have it, but I'm not sure about the 1.5L. Thank you.
When the rear fog light on the 2021 SAIC Volkswagen T-Cross 1.5L Comfort version is turned on, only one side will light up.
Are you using 92 or 95 gasoline for the 2021 T-Cross 1.4 Comfort version?
Has anyone replaced their car battery? I drive often, and last night the battery was dead and I couldn't start the car. Have you guys encountered this before?
Has the T-Cross been recalled for a fuel pump replacement at the 4S shop? Have you noticed higher fuel consumption after the fuel pump was replaced?
