فهد رومي
2024-07-05 13:03
Do any of you fellow car enthusiasts feel that the 1st and 2nd gears are noticeably jerky?
عبدالله عوادة
عبدالله عوادة2024-07-11 23:37
When shifting between 1st and 2nd gear, you might experience noticeable jerking. This can be caused by various factors, such as mechanical issues, driving technique, and the characteristics of the vehicle itself. Therefore, addressing this problem requires analysis and handling from multiple perspectives.
My 2012 C30 has been driven for 78,000 kilometers. Now, when I drive, the 2nd and 3rd gears feel jerky and lack power. What could be the reason?
What viscosity of engine oil do you use for your new Mazda5? What's your fuel consumption? And does your transmission shift from 1st to 2nd or 2nd to 3rd gear smoothly? I'm experiencing some jerking.
Is the strong jerkiness when shifting from 1st gear to 2nd in your GA8 a common issue, or is there a problem with the car?
Hey folks, my 2017 Haval H2 manual is jerky between 1st and 2nd gear. It feels really tough to shift gears. What's going on here?
Hey folks, does your 95 feel jerky when slowing down? I feel the jerkiness is quite noticeable, but I see comments saying there's no jerkiness. 🤔
Hey car enthusiasts, how do you guys shift gears with a 1.3L manual? 2nd gear at 20-40, 3rd at 40-60, 4th at 60-80, and 5th above 80!
Does the S gear shift up and down? Why can it only be in 1st gear and not in 2nd, 3rd, or 4th gear?
Hey fellow car enthusiasts, do all fuel-powered cars experience jerking when shifting gears? Mine does when shifting from 1st to 2nd. In this situation, will the dealership replace the electro-hydraulic module?
Hey fellow car enthusiasts, do you also notice that when you start the car in P gear, the engine revs quite loudly, usually above 1000 RPM? But once you shift to D gear, it drops below 1000 RPM and the sound gets much quieter. Is that the case for you too?
