2020 Volkswagen T-Cross, registered in 2021, and in 2022 the keyless entry stopped working, so you can only use the remote to unlock the door. Does anyone know what might be the issue?
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
Why does the keyless entry only lock but not unlock the car?
4How do you control the window lowering with the remote on the 2022 T-Cross 1.5 NA version? Can any fellow car enthusiasts give some guidance? 🤗🤗🤗
5Volkswagen T-Cross
6When the rear fog light on the 2021 SAIC Volkswagen T-Cross 1.5L Comfort version is turned on, only one side will light up.
7Can the 2021 T-Cross be equipped with a digital key?
8The car won't lock with keyless entry, and there's a beeping sound. How can I fix this? It unlocks fine, but there's a beep when trying to lock.
9Are you using 92 or 95 gasoline for the 2021 T-Cross 1.4 Comfort version?
10Is there anyone who knows why the 2020 T-Cross makes a strange noise when turning the steering wheel?
