When driving the 14th generation Sylphy with over 20,000 kilometers, there's a "zhe zhe zhe" noise from the rear tires, similar to brake pad friction. Not sure what the reason is.
I want to ask, why is the front brake caliper of the Taycan positioned at the front? Isn't it said that for mid-to-high-end cars, the front wheel calipers are generally positioned at the rear? Please explain.
Has anyone experienced a whistling noise while driving the all-electric Lavida? Not sure what the reason is. Could it be the brake pads? But it makes the sound even when I'm not braking. It comes and goes.
Looking for rear brake pads for Smart 453.
4Can I buy rear brake pads?
5When turning the steering wheel all the way to the right while reversing, it feels like the wheels are rolling over something, with an up-and-down sensation, similar to the feeling of an uneven tire.
6I'm driving a 2021 1.4T Comfort T-Cross, and it's run less than 20,000 miles. There have been two instances where it suddenly braked and paused while driving normally. What's the reason for this? Does anyone know?
7Hey car enthusiasts, my 2011 manual Alto has done over 70,000 kilometers and needs new front brake pads. Could you recommend a good quality brake pad for me to check out? Thanks!
8Did anyone with the 2021 Cayenne experience similar noises? 1. There's a sound similar to backfire when the engine stop-starts cold. 2. There's a noise when braking, even after replacing all four brake pads and discs. It's a screeching sound, quite piercing, like a large truck's brakes. 3. The sunroof screen and sunshade have been making noise since I got the car, and it hasn't been resolved. Anyone with the same issues? Any solutions? Looking for help.
9When the car speed is within 20 km/h, there's a squeaking noise from the left rear wheel, and the brake pads are normal.
10How to fix the long brake travel on a 2014 Santana? The brake pads are thick, the rear drum brakes have been tightened, and the brake fluid has been changed. Recently, the brake travel has become longer, and I'm not used to it at all. When I press the brake, it feels like there's a hissing sound under my foot. Several mechanics said they can't adjust it. Any suggestions on which part needs to be replaced? Thanks!
