What engine oil do you recommend for a 10,000-kilometer maintenance?
How do you reset the maintenance indicator, and how much engine oil is needed?
What engine oil do you all use for diesel versions?
What type of engine oil do you all use?
4For the 2013 model of GAC GS5 with a 2.0L naturally aspirated engine, what type of engine oil do you recommend for maintenance?
5How many kilometers do you usually drive before servicing your BRZ, and what oil do you recommend?
6What maintenance should be done at 100,000 kilometers? Do the transmission oil and gear oil need to be replaced?
7What oil do you all use for maintenance?
8I've driven my 2024 Wrangler for 10,000 kilometers. The first service was done at the 4S shop at 5,000 kilometers. They suggested I service it again at 10,000 kilometers. Do I need to change the engine oil this time?
9What grade of engine oil do you use?
10Do you use fully synthetic or semi-synthetic oil for your 10,000 km oil change?
