Hey folks, I have a question about my Nissan Sylphy Classic. I've installed a central control screen, and when I'm playing music and using navigation at the same time, the music cuts off whenever there's a navigation prompt. How do I fix this?
Does the 2008 Mazda3 (imported) 1.6L automatic version without a central control screen use a USB drive or CDs for playing music?
Is your CarPlay music playback smooth? How do you fix any issues? Also, the automatic lock/unlock feature sometimes doesn't work properly, which is frustrating. Additionally, after turning off the engine, the power cuts off immediately, so I can't close the windows if I forget. Lastly, when starting the car, I have to manually turn on the central control. Is this a settings issue on my part? How do you all deal with these issues? Or am I the only one experiencing them?
Why is there no sound when I connect Bluetooth after modifying the Patrol's central control, even though the music app built into the central control has sound and shows that it's playing? 😢
4Hey folks, has anyone experienced issues with NetEase Cloud Music not playing? I parked for a day and then it stopped working. Voice commands can wake up and execute on Zebra, but NetEase Cloud just won't play. Even restarting the car system doesn't help.
5RDX car display screen has no sound while navigating and playing music, and there's no image response when turning right. Can anyone let me know the reason?
6Does the Nissan X-Trail Classic have a leakage issue? Should I cut off the sunroof drain hole insect screen in advance? Should I use underbody armor spray?
7I'm asking about the new 009 model regarding the HUD issue. I'm 186 cm tall, and during the test drive, I noticed that the HUD display is not fully visible. The top part is cut off due to the angle. I've already adjusted the HUD to the lowest position, and my seat is also set to the lowest and a relatively back position. Even then, in a normal sitting posture, the top of the HUD is still a bit cut off, and I have to lower my head to see all the HUD information. Are there any other owners with the same issue? Also, can the 009's HUD display information from QQ Music, like selecting a song to play or displaying lyrics?
