عمر هاماوي
2024-03-05 01:04
When turning the steering wheel all the way to the right while reversing, it feels like the wheels are rolling over something, with an up-and-down sensation, similar to the feeling of an uneven tire.
عبدالله هارون
عبدالله هارون2024-03-09 21:05
I have the same issue when turning the steering wheel all the way to the left.
سعود زاهر
سعود زاهر2024-03-05 13:31
You're being too rigid, it's fine. Just go with the flow.
How to fix the steering wheel pulling to the right?
Why does the Ford F150 feel particularly sluggish when I engage 4WD, turn the steering wheel all the way, and accelerate?
Do your reversing assist lines move with the steering wheel?
How do I adjust the steering wheel up and down on the 2019 model of Yuxiang?
When reversing and turning the steering wheel, there's a clunking sound coming from the right front wheel. Sometimes it also sounds like the tire is crushing gravel. What could be the issue? There's no noise during normal driving, only when reversing or turning the wheel to a certain angle. Is it due to worn-out control arm bushings or is it an issue with the steering rack?
Nissan Patrol, 98k kilometers. Now when I turn the steering wheel all the way, it gets stuck, and I can't turn it. Also, when reversing, it doesn't move. Has anyone else experienced this issue?
What could be the reason that the brake pedal cannot be pressed down when turning the steering wheel fully or reversing?
Hey folks, my 2014 Haval H2 makes a buzzing noise when I turn the steering wheel all the way while reversing. What's going on?
I've got a 2022 GTS with over 10,000 km on it, and I've noticed an issue. When I turn the steering wheel all the way while moving forward or reversing, there's sometimes a loud noise from the chassis. It sounds like something is stuck or like a brake squeal. Has anyone else experienced this?
Suzuki Suzuki SX4
Suzuki SX4TBDPetrol
