خالد سالم
2024-03-24 17:56
When driving at high speeds, there's a ticking noise from the driver's side window that sounds like raindrops hitting the glass. At first, I thought it was raining, but it wasn't. The right window is fine. The noise disappears when I lower the window. Could it be caused by the window seal? Has anyone else experienced this? How did you solve it?
حمزة عمر
حمزة عمر2024-04-10 19:46
Lift bracket issues, common problem! That's how it is with old cars.
Has anyone experienced the driver's door window on the Scirocco only lowering a little bit when opening the door? What could be causing this issue?
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
Is the severe shaking of the driver's side window when lowered a common issue with the Lingfang?
Is there anyone with a Levante experiencing a ticking noise when idling after warming up the car? The noise disappears when you press the accelerator a bit. What could that sound be?
Do you have a link for the window glass inner seal strip?
Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
When the window glass in the Outlander's cabin is lowered and the door is closed with a bang, what's going on?
When the car's rear window glass closes to the top and then immediately slides down, what could be the issue?
Do you have issues with window noise? When the car is parked outdoors, during rainy or very hot days, after starting, there's a creaking sound from the rooftop or windows, which disappears after driving for a while. I should mention that if it's parked in an underground garage, there's no noise. Even after reopening and closing the sunroof, the problem persists. When the noise occurs, it gets louder if the road is uneven. The model is a six-seater.
Suzuki Suzuki SX4
Suzuki SX4TBDPetrol
