How to check the transmission fluid dipstick: Is it normal for the fluid level to be almost one notch above the maximum hole when the car is cold?
When you slow down to stop, and the RPM suddenly goes up to around 2000 before dropping, it could be related to the transmission downshifting or the engine management system adjusting for some reason. As for the brakes feeling a bit soft, you might want to check the brake fluid level or have the brake system inspected for air or leaks. If anyone has more insights, please share. Thanks!
If your manual transmission 2.0 car with 120,000 kilometers is making a metallic clashing sound above 80 km/h, it might be related to the transmission chain. However, manual transmissions typically do not have chains; they usually have gears. It might be a good idea to have a professional mechanic check it out to pinpoint the exact issue.
4Hey guys, my 2014 Alto's coolant temperature doesn't go above 80 degrees. Is this normal? Should I replace the thermostat? Which one is better, the original or from Tenpu?
5Hey fellow car enthusiasts, my car seems to be burning oil. After about 7000 km on full synthetic oil, the dipstick shows it's almost at the minimum level 😭. This has happened in the last two maintenance sessions. It's a 2017 Jeep Compass with 120,000 km over 6 years. Has anyone else experienced engine oil burning, and how did you resolve or repair it?
6Hi, for a 2011 Suzuki Swift 1.5 automatic that's run 110,000 km, here's what you might want to consider for maintenance to avoid getting ripped off: 1. **Oil Change**: Check and replace the engine oil and oil filter. 2. **Transmission Fluid**: Inspect and possibly replace the transmission fluid. 3. **Brake System**: Check the brake pads and brake fluid. 4. **Coolant**: Inspect the coolant level and top up or replace if necessary. 5. **Air Filter**: Check the air filter and replace if dirty. 6. **Tires**: Check tire pressure and tread wear. 7. **Battery**: Test the battery to ensure it's in good condition. 8. **Belts and Hoses**: Inspect for any wear and tear. It's always a good idea to consult your vehicle's manual or a trusted mechanic for specific recommendations.
7How to check the transmission fluid dipstick: Is it normal for the fluid level to be almost one notch above the maximum hole when the car is cold?
8Looking to buy a dipstick for the transmission fluid of a 2011 model 2,496. Is there an original one available?
9The air conditioning was set to level 4, but there was still barely any cold air and the airflow was very weak. What's going on? After a day, it went back to normal. It's really frustrating.
10Does your 1.6 naturally aspirated engine consume oil too? Mine has only run about 90,000 kilometers, and after the last maintenance, I drove less than 2,000 kilometers before the oil light came on. When I checked the oil dipstick, it couldn't even reach the oil level.
