عبدالرحمن علياء
2024-04-25 14:06
Hey everyone, I've got an issue with my 09 model. Sometimes while driving, there's a sharp "dang dang" sound coming from underneath the car. It comes and goes, and sometimes I can even hear it when idling. The repair shop mentioned it might be the exhaust pipe but then said it doesn't seem like it. They think it might be coming from the bottom of the engine. Have any of you experienced something similar?
Sometimes when I'm driving my X90 on the highway, there's a humming sound coming from the engine compartment. What could that be?
The 2014 model with a 3.5L engine shows the engine warning light and exhaust system fault light at 100,000 km. The sensors have been replaced, but after a while, the lights come on again. Does anyone know what the reason might be? Generally, the lights only come on when driving at high speeds. Could it be related to the Evans waterless coolant that was changed a few years ago at the 4S shop?
My 10-year-old 1.6 manual Peugeot 307 sometimes makes a sharp "squeak" sound, like metal rubbing against metal, when I'm shifting gears, releasing the clutch, or letting off the accelerator. Does anyone know what might be causing this? 🥲
The engine number for the 2009 Range Rover Sport with a 3.6-liter engine can typically be found on the engine block itself. It's often located on the side of the engine, usually where the engine meets the transmission. You might need to look from underneath the vehicle or consult the owner's manual for the exact location.
Anyone else experiencing occasional rattling noises from the 24 model's dashboard? It sometimes goes "dang dang dang," but when I take it to the dealership, the noise disappears and they can't find the issue.
I have a 2024 model with a 2.0 engine, and after modifying to a quad exhaust, there's a resonance between 2000-2400 RPM. It's more noticeable at high speeds, and the sound seems to come from the right rear exhaust in the cabin. Has anyone experienced something similar? The issue persists even after removing and reinstalling the exhaust tips, so it's not due to loose fittings.
Do you have any abnormal noises coming from the center console of your car? When in Drive (D) and holding the brake, there's a "dang dang dang" sound from the driver's center console. There aren't any issues in other gears.
Is there anyone who bought this car in 2024? I've seen posts from long-time owners mentioning so many issues. I'm picking up my car in a couple of days, and I'm really worried it might have the same problems.
When driving on uneven roads, there's a jingling noise coming from the rear of the car. But when the windows are closed, the sound can't be heard. What could be the issue? I suspect it might be the silver trim at the rear.
Suzuki Suzuki SX4
Suzuki SX4TBDPetrol
