خالد عَبْدُ الله
2024-04-26 23:16
Does your engine also make a loud noise when the RPM reaches 2000? Especially when going uphill, all I can hear is the roar of the engine.
نايف عوض
نايف عوض2024-04-28 23:20
Yes, when the RPM goes up, release the accelerator and then slowly press it again. The noise might reduce a bit.
When driving the 2014 Foton Tunland 2.8S 4WD, there is a noticeable humming vibration in the cabin when the alternator speed is below 1600 RPM. However, once the engine speed reaches 2000 RPM, the humming sound disappears. Could any experts advise on what might be causing this issue?
Hey guys! Does anyone else experience weird noises when their car's RPM goes above 2000? It sounds like a roaring noise, and I feel like it might be an issue with the intake or exhaust!
When the RPM reaches 2800, there's a loud roaring noise, but after 3000 RPM it disappears. What's going on? [Cover face]
When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
I have a 2023 Jietu X90 Zilong Changsheng version. When starting and accelerating, the engine roars loudly. Is it the same for everyone? There's no engine noise when it's idling, but as soon as I press the accelerator to start, the engine sound is quite loud.
Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
Does anyone else experience their engine roaring at 2000 RPM?
Is there anyone who can answer a question: Is the engine noise of the 2024 Prado loud when climbing hills or driving continuously uphill?
Suzuki Suzuki SX4
Suzuki SX4TBDPetrol
