حسن ظافر
2024-03-06 00:37
Does adding fuel additives really help clean carbon deposits? Is it a waste of money or truly effective? Let's discuss, fellow car enthusiasts.
Comments( 6 )
محمد عادل
محمد عادل2024-05-22 09:55
It's useful. I previously used an endoscope to check, and after using two bottles of additive, I did see that a portion had indeed dissolved.
عبدالرحمن وسيم
عبدالرحمن وسيم2024-05-05 19:51
It's useful, but it depends on the condition of your car. For some cars, after using fuel additives, the catalytic converter gets clogged, triggering fault codes, and the sludge in the engine is washed away.
نايف قنصوح
نايف قنصوح2024-05-05 13:21
I'm using it and it feels okay. The fuel consumption isn't high anyway.
خالد سالم
خالد سالم2024-03-11 21:53
I don't know either. Others say it's a "IQ tax."
بلال نايف
بلال نايف2024-03-06 11:42
There's no need to use fuel additives for a naturally aspirated car. Just make sure not to use fake engine oil, and you're good to go.
عبد العزيز قاسم
عبد العزيز قاسم2024-03-06 08:16
Very effective, add a bit more, it can clean out the injectors. 👏👏👏
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
Should I clean the carbon deposits in my Kia Sportage manual transmission after 90,000 kilometers?
Has anyone used fuel additives for carbon deposit cleaning? Do they work well?
Fellow car owners, how do you clean carbon deposits from your car? Which brand of fuel additive works well? Any recommendations?
How to Clean Carbon Deposits in Vitara
My Jietu X70 has run 30,000 km, and when I cold start it, the idle is unstable, and the car shakes. After about ten seconds, it gets back to normal. There's no error displayed. I left it at the 4S shop for a week, and they cleaned the throttle, carbon buildup, and fuel injectors, but it didn't help. The 4S guys said it might be the fuel, so I switched gas stations, but there's still no change. Has anyone else experienced this? How did you solve it? Please let me know. 🙏
Suzuki Suzuki SX4
Suzuki SX4TBDPetrol
