The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
SAIC Maxus 2020 T60 2.0T diesel 4WD, 1.5 years old. There's a vibration noise coming from the center console when the RPM is between 1800 to 2000 in low gear. What could be the cause?
Is there a solution for the Kia Sportage valve cover oil leak? Is it a common issue? I bought a 10-year-old manual second-hand car.
Are there any GV80 owners experiencing a vehicle vibration issue transmitted to the pedal and steering wheel at around 1500 RPM before each gear shift, while driving at a speed of 40-80 mph?
4Hey folks, my manual Legacy feels powerless under 2000 RPM. Even when I step on the gas pedal hard, there's no response. What's going on?
5The 2017 Land Cruiser with an automatic transmission struggles to accelerate when flooring the gas pedal, with the RPM not going above 2300, causing slow acceleration. However, when using cruise control, the acceleration is faster, and the RPM can increase. What might be the reason for this?
6The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵💫 Do any other T-Cross owners experience this situation?
7The 10-year-old 1.5 manual car experiences severe vibration in the gas pedal at 3000 RPM in any gear, making it difficult to press. Does anyone have a solution for this issue?
8Has anyone experienced repeated jerking at a certain RPM (mine is at 1500-1600)? Lightly pressing the accelerator to maintain this RPM causes repeated jerking, but it stops if I accelerate more or release the pedal. This issue has randomly appeared several times and then mysteriously resolved itself.
9Hey car enthusiasts, can anyone help me out? My 2015 manual Sunny only revs up to 2000 RPM when I floor the gas pedal, and the acceleration feels weak. What could be the issue?
10Is your 2015 Jetta also like this, where the RPM only reaches around 3800 when you floor the gas pedal in neutral and doesn't hit 4000?
