عبدالله معاوية
2022-05-13 16:03
Is your air conditioning cool enough? Other cars can go down to 16 degrees, but I feel like the Swift only goes down to about 22 degrees. It's not very cool, but not too hot either. 🤦‍♂️
Comments( 11 )
علي طلحة
علي طلحة2024-04-08 15:40
[Wǒ xiǎng jìng jìng] Shifting into first gear almost got me frostbite (exaggeration). It's really cold.
محمد ممدوح
محمد ممدوح2022-08-06 18:47
The Swift is a small car, and even with the air conditioning set to level 2, it feels a bit cold.
عمر جعفري
عمر جعفري2022-08-06 17:28
The official requirement for adding refrigerant to the Suzuki Swift's air conditioning is 480 grams.
محمد سليم
محمد سليم2022-08-06 08:19
My Kai 4 is a bit cold, around 18 degrees.
حسن شاكر
حسن شاكر2022-08-05 22:25
Added three cans of refrigerant, and when I got off at the service area on the highway, my glasses fogged up completely. Maybe it's because of the high humidity outside. 🤔
أحمد ضربة بكوع إير
أحمد ضربة بكوع إير2022-07-27 00:31
When driving, the temperature is as low as 5 to 6 degrees. When stopped, the temperature rises to around 10 degrees.
عبدالرحمن فيصل
عبدالرحمن فيصل2022-07-03 19:57
The air conditioning in the Swift is really cold. [I want some peace and quiet]
عبدالله هادي
عبدالله هادي2022-07-03 00:40
Yes, I replaced my entire air conditioning system, and spent a lot of money on it, but it's still not very cool. Plus, the noise is really loud when I turn it on.
عبدالرحمن لحود
عبدالرحمن لحود2022-07-02 21:17
My car isn't cooling well either. [Crying] I just added 4 cans of refrigerant and also cleaned the evaporator.
علي زبير
علي زبير2022-05-14 00:22
My air conditioner is still working well. In the summer, it cools down in just two to three minutes, and the cooling effect is excellent.
My 2002 Acr30's air conditioning has an issue. When I set the temperature above 18 degrees on either manual or automatic mode, it blows hot air, and there's an engine oil smell coming through. However, if I set it below 18 degrees, it blows cold air and the oil smell disappears. Has anyone else experienced this with their car, and how did you deal with it?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Is it normal for the left side of the hood on the 2019 HS 2.0 Super Edition to be hot after parking? After about half an hour, it cools down and the whole hood is warm, but the temperature is acceptable.
I've got a 2009 Peugeot 307, and the air conditioning isn't cooling very well. I had it recharged with refrigerant, but it still doesn't get cold enough, especially on hot days. Any idea what might be wrong?
Is the air conditioning in your cars cool enough at noon when it's 38 degrees? I'm about to melt from the heat.
Yesterday, I went to the dealership to check the air conditioning pressure. It was at 16 psi and the temperature was 7.6 degrees, and they said everything was fine. But by noon, it wasn't cooling anymore. 🤦‍♂️
Suzuki Suzuki Swift
Suzuki SwiftAED 48,900 ~ 60,000Gasoline & Petrol
