Is a 2010 automatic 1.3 Suzuki Swift for 24,000 too expensive? The previous owner added a tint, which I really like. It has 70,000 kilometers and comes with half a year of insurance.
Comments( 17 )
2008 Suzuki Swift, 1.3L, automatic, 100,000 km, original catalytic converter, large screen navigation, reverse camera, modified headlights. Priced at 11,000. Is it expensive?
