What could be causing the severe engine vibration in a Viano?
When coming to a stop, the idle speed suddenly drops and it feels like the car is about to stall. This occasionally happens when shifting from D to P while stationary. I've replaced the spark plugs, ignition coils, injectors, high-pressure fuel pump, PCV valve, carbon canister solenoid, air flow sensor, and engine mounts. I've also cleaned the intake carbon deposits and combustion chamber carbon deposits. The problem still exists. Can anyone help me figure this out? [crying][crying][crying][crying]
I've got a 2012 Changhe Liana, and it's been having issues with shaking at idle, while driving, and even more when the AC is on. I've already replaced the spark plugs and ignition coils, and cleaned the fuel injectors and throttle body, but the problem persists. The check engine light comes on frequently. Does anyone know what might be causing this issue?
4When driving the 2017 1.5T Smart model at 55 mph, the engine makes a roaring noise, but it disappears after accelerating past 60 mph. I've cleaned the throttle body, removed carbon buildup, and changed the engine mounts, but the issue persists. I've heard that reprogramming might help, but it carries some risks. Has anyone encountered this problem?
5I've got a 2013 Kia Sportage Manual GL 2.0, and the steering wheel shakes when idling. I've cleaned the carbon buildup in the engine cylinders, the injectors, and the idle valve. I also replaced the spark plugs and engine mounts last year. Any experts out there have any advice?
62010 Changan Yuexiang, experiencing body vibration at low speed and low RPMs. The symptom disappears at higher speeds. What could be the issue? Is it the valves or are the engine mounts worn out?
7It could be due to several reasons such as engine misfire, idle air control valve issues, or even problems with the transmission mounts. It's best to have a mechanic check it out to diagnose the exact cause.
8After cleaning the throttle body yourself, the engine warning light came on. It doesn't affect driving, but how can you resolve this?
9If your 2010 Suzuki Swift 1.5 automatic is still shaking after replacing the spark plugs, ignition coils, PCV valve, and EGR valve, there could be other issues at play. Some potential causes could be: - Engine mounts: Worn or damaged engine mounts can cause vibrations. - Fuel injectors: Clogged or malfunctioning fuel injectors can lead to engine misfires. - Throttle body: A dirty or faulty throttle body can affect engine performance. - Air intake system: Check for any leaks or blockages in the air intake system. - Transmission issues: Problems with the transmission can also cause vibrations. You may want to consult a professional mechanic to diagnose the issue more accurately.
10What could be causing this issue with the 2011 Volvo C30? When shifting to 2nd gear, the engine makes a buzzing noise. There are no fault codes, but there is a throttle body fault code for the engine.
